03-02-2023 08:19 AM
Does any one know why when I ask Google assistant to start cleaning, the robot doesn't start? It says "starting the robot vaccum" though. I have unlinked and reconnected dreamcatcher life.
03-07-2023 10:25 AM - edited 03-07-2023 10:27 AM
Hello ArisG,
Thanks for reaching out and I'm sorry for this experience.
I'm checking in to see if you're still having trouble controlling your robot vacuum. Check out these supported voice commands for Dreamcatcher Life vacuums and let me know if all of them work or not.
Lovely
03-07-2023 10:52 AM
Thanks for your answer! Somehow it worked with the same commands I used before. I restarted the nest hub once and that might be the solution. So, now it works fine!
03-07-2023 11:15 AM - edited 03-07-2023 11:21 AM
Hey ArisG,
Many thanks for the update! I'm glad that your voice commands have now worked. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Lovely
