07-10-2023 05:26 AM
I have setup a bedtime. One of the actions set is to ask for "what time to set the alarm for". Once the alarm is set the routine ask a second time for what time the alarm should be set.
Is anyone else having the same problem?
07-17-2023 05:03 PM - edited 07-17-2023 05:07 PM
Hi Sukhjits,
This is not the experience we want you to have; let us help you. A few questions: which Nest speakers are we working with? When did your issue begin? Were there any recent changes made? What country are you located in?
It would help a lot if you could do a sequential reboot first:
Also, you can re-establish the routines by either removing the current one and creating a new one or editing the current routine actions. For more detailed instructions, open this link.
Let us know how it goes.
@robertrodriguez, for us to be on the same page, may I know if you have concerns regarding Google Home routines?
Dan
07-18-2023 08:36 AM
I am in the US, it is the Nest hub(2nd generation). Have tried everything you mentioned. The issue has been going on now for about 4 months. There have been no changes.
08-16-2023 11:39 AM
Hi Sukhjits,
Thanks for the details you've shared and sorry for the delay. If possible, are you getting the same response when you use another Nest speaker or display? How about using your phone’s Google assistant?
Juni
