05-29-2023 04:49 AM
Have rebooted nest hub, deleted and reinstalled home app but when trying to use iPad to change volume or look at display/photos says not connected to wifi even though both are. Works ok with an android phone. Any ideas?
06-20-2023 09:21 AM
Helllo rayofsunshine,
I know how important it is for you to be able to access and control your Google Nest Hub using your iPad Air 5. Let's try to get to the bottom of this. To confirm, has it worked on your iPad Air 5 before? What is the iOS version of your iPad Air? Are you using a dual-band router? How far are you from the Nest Hub when you try to control it using your iPad Air?
Since the issue is isolated to the iPad Air 5 only, I suggest that you check with Apple to see if there are settings that prevent your iPad Air from connecting with other devices.
Muddi
06-23-2023 11:11 AM
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
06-28-2023 12:30 PM
Hello there,
Just checking in to make sure that you saw our responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Juni
