01-23-2024 05:29 AM
Hello everyone,
I'm attempting to make my own set of Home/Away routines that can be interrupted in case we have a babysitter or guest staying over (so that all our lights and the heating/cooling doesn't shut off on them if we leave). I currently have the following Away Routine which works perfectly:
metadata:
name: 1 Away Mode
description: Turn off all the lights when we are away, except when Guest Mode "plug" is activated
automations:
starters:
- type: home.state.HomePresence
state: homePresenceMode
is: AWAY
condition:
type: device.state.OnOff
state: on
is: false
device: Guest Mode - Guest
actions:
- type: assistant.command.OkGoogle
okGoogle: Turn off all the lights
devices: Family Room Audio - Family Room
- type: device.command.OnOff # Turn the device on or off.
on: true
devices: Front Door Cam Plug - Kitchen
- type: device.command.ThermostatSetMode # Set the target operating mode for a thermostat device.
thermostatMode: eco
devices: Thermostat - Dining RoomWhere I am struggling is with the Home routine:
metadata:
name: 1 Home Mode
description: Turn the thermostat back on when returning home
automations:
starters:
is: HOME
actions:
thermostatMode: on
Right now the options for thermostatMode are on, off, eco, heat, cool, and heatcool. "eco" turns on eco mode, but there is no way to turn eco mode off. You have to specify heat, cool, or heatcool. On only turns the thermostat back on if it is off.
Right now, I'm just trying to remember that as we change modes, we need to manually update the script to match. But is there a way to just turn off eco mode, or remember the previous mode from the Away routine and reapply it to the Home routine?
09-13-2025 07:57 AM
For anyone else who has this issue. I was able to resolve it with the help of Samsung SmartThings. Since Google Home doesn't have the ability to store global variables, I use virtual switches. I made three switches modeheat, modecool, modeheatcool (named so that someone doesn't accidentally ask to turn on heat mode and activate them outside of the thermostat and they get out of sync). I then made three rules in Samsung SmartThings that if one switch turns on, the others turn off.
Once SmartThings was setup, I had to make a couple of new scripts to sync everything:
#1 Three routines for syncing the switches to the thermostat state:
metadata:
name: z Sync Thermostat Cool
description: Whenever the thermostat changes modes, turn on the correct virtual switch
automations:
starters:
- type: device.state.TemperatureSetting
state: thermostatMode
is: cool
device: Thermostat - Dining Room
actions:
on: true
devices: modecool - zAutomations
#2 A routine to turn off all switches if the thermostat is set to OFF
metadata:
name: z Sync Thermostat Off
automations:
starters:
is: off
actions:
on: false
devices: modeheat - zAutomations
on: false
devices: modeheatcool - zAutomations
on: false
#3 Edit the Custom Home Routine to set the thermostat to the correct mode
metadata:
name: 1 Home Mode
description: When coming home, reactivate the thermostat and set it to the previous mode
automations:
- starters:
is: HOME
condition:
device: modecool - zAutomations
state: on
is: true
actions:
thermostatMode: cool
- starters:
is: HOME
condition:
device: modeheat - zAutomations
state: on
is: true
actions:
thermostatMode: heat
- starters:
is: HOME
condition:
device: modeheatcool - zAutomations
state: on
is: true
actions:
thermostatMode: heatcool
Hopefully this helps someone else who has the same situation as me!
09-13-2025 07:57 AM
metadata:
automations:
starters:
is: cool
actions:
on: true
metadata:
automations:
starters:
is: off
actions:
on: false
on: false
on: false
metadata:
name: 1 Home Mode
automations:
- starters:
is: HOME
condition:
state: on
is: true
actions:
- starters:
is: HOME
condition:
state: on
is: true
actions:
- starters:
is: HOME
condition:
state: on
is: true
actions:
09-13-2025 08:00 AM
One additional item, I had to change the name of the "Guest Mode" switch to "Away Mode". Apparently, there is a new guest mode for Nest Speakers that disables saving your history (and it terribly difficult to disable once it's been enabled!) With the new name, I had to switch the logic. "Away Mode" ON means do everything normally. "Away Mode" OFF means don't turn off all the lights on the babysitter.
