01-27-2026 11:47 PM
Hello everyone,
As of today, my Google devices (Nest Mini and Nest Hub) suddenly speak English, even though everything worked perfectly in German before.
I have already checked and done:
In my Google account, German (Germany) is the only assistant language
English has been completely removed
Device language set to German
Devices restarted
Gemini checked, deactivation is not possible
Nevertheless, the devices continue to respond in English or switch back to English after a short time.
Before, everything worked smoothly. Does anyone else have the problem? Are there any tips on how to get the devices permanently in German until Google provides a fix?
Thanks for your help!
01-28-2026 02:40 AM
I also have the same problems and tried the same fixes. Sadly it doesn't work. What helps a bit is to change all names of devices and rooms to english names, so at least it works in english. Gemini is so stupid and every day more stupid in some way. I will switch to Amazon Alexa now. My Family can't take this anymore
01-30-2026 12:34 AM
Bei mir hat es nur geholfen dass zu Hause zu löschen und neu einzustellen. Laut Google gibt es die Gemini Version die geupdatet wurde nur auf englisch und nächstes Jahr ab Deutsch deswegen bleibt ein Zurücksetzen und löschen das Ganze zu Hause ist die einzige Option
