06-10-2024 03:04 PM
I'm looking for a set up a Automation/Routine to have a room fan (Not the Air handler fan) fan start via smart plug (this plug is set up and working in Google Home) when cooling starts from the Nest thermostat. Similarly to have this room fan stop when cooling stops or stops after a set amount of time 5-15mins.
I For starters of my Nest Thermostat there is "Mode changes to: " I thought this would be the ticket but alas the mode is not changning when cooling comes on and off. The thermostat is still in cooling "mode" whether the cooling is active or not.
The other starter available for the thermostat is temperature but this does not meet my scenarios since the cooling may turn on and off at different temps depending on Temperature presets the thermostat is currently operation in. ie. Day, Away , Sleep
I'm doing this in the Android Google Home app.
If anyone has any other clever ideas I might obtain the intended results I'd like to hear it.
I also wonder if there are other starter options available be in Google Home for web script editor that is currently in Public Preview.
https://support.google.com/googlenest/answer/13323253?visit_id=638266077660237803-381182716&p=script...
Thanks in adavance
06-18-2024 12:05 PM
This can be done but you'll have to use the yaml scripting editor at home.google.com
06-18-2024 02:08 PM
Thanks for the reply @GBD. I did start to tinker in script editor. I'll have to do some testing and see if I can get it working as intended but good to know if someone else thinks this should be possible.
I may reply with my solution or if I run into any questions that you or others might be able to help me with.
06-19-2024 05:39 AM
You're welcome @GN2p. The specific starter that you'll be looking for would look like this.
starters:
- type: device.state.TemperatureSetting
state: activeThermostatMode
is: cool
device: xxxx - xxxxxxx
You can use the same script to both start and stop your fan, you just need to be careful of your indentations in the script. For turning the fan off the is: would be replaced with isNot:
Here is the script that I use to control cooling and humidity using a portable and window ac unit.
metadata:
description: Unified script for controlling portable/window AC temperature and humidity
automations:
- starters:
- type: device.state.TemperatureSetting # For devices that support temperature points and modes.
is: cool
device: Zone 1 - Dining Room
actions:
- type: assistant.command.OkGoogle
okGoogle: activate scene AC1 power on
devices: Den Mini - Den
- type: device.command.OnOff # Turn the device on or off.
on: true
devices: Geeni Switch 1 - Living Room
- starters:
isNot: cool
actions:
okGoogle: activate scene AC1 power off
on: false
- starters:
state: thermostatHumidityAmbient
greaterThan: 60
for: 5min
suppressFor: 30 min
condition:
type: and
# "AND" together two or more conditionals
conditions:
isNot: cool
state: thermostatMode
is: cool
actions:
okGoogle: activate scene AC1 dehumidify
- starters:
lessThan: 58
condition:
type: and
conditions:
is: cool
is: cool
actions:
okGoogle: activate scene AC1 off
