11-29-2025 10:47 AM - edited 11-29-2025 10:48 AM
Oh boy! I get to make a double gripe today. First, whenever I use an automation that I've used hundreds of times, the speaker will perform it as usual, but then start its LEDs scanning endlessly. It will not stop until I use the wake phrase again. I don't have to issue a command. It will just stop after it acknowledges my command.
Secondly, who thought it would be a great idea to remove the ability to assign names to timers? Yeah, this works great if you have three timers running simultaneously.
Google is making me regret switcing from Alexa. Stop screwing up the system.
12-02-2025 01:05 PM - edited 12-02-2025 01:13 PM
Hi TE5LA,
Thank you for posting in the community. I see you're having trouble using an automation on your Google Nest Speakers which are running as usual, but then the speaker LEDs begins scanning continuously until you say the wake-up command again. I also note your concern regarding the inability to assign names to timers. I appreciate all the detailed information you've provided, and I understand how frustrating this can be. I'm here to help.
For better assistance, please answer the following questions:
Additionally, regarding the ability to assign names to timers, we're always looking for ways to improve. Please consider sharing your thoughts and insights by submitting them through the feedback form so we can implement improvements in future updates.
Please keep me posted on your findings.
Byron
12-02-2025 02:02 PM - edited 12-02-2025 02:05 PM
It is a Google Home Bluetooth speaker, the sort of flattened cylinder with cloth all over. It has four LEDs on the front.
This started a few weeks ago, I guess. Around the same time as an update to Home Assistant. It affects two automations for the same equipment. Two devices to simply turn on and off. These automations have been used for around 2 years. Nothing has been changed here. This doesn't occur with any other automation. It doesn't happen if I give the two commands in the automation as independent commands, only when they are in an automation.
I have already tried rebooting the speaker and creating a new automation with the same commands. It is still the same. The LEDs scan from left to right across all four in white. They will continue for eternity unless I say, "Hey, Google." I don't need to issue another command. They just stop after waking the speaker.
This is very annoying.
Also annoying is the fact that naming timers had been removed. Previously, you could say, Hey, Google. Set a 30-minute timer named oven," and it would confirm the timer and name, and announced the name at the end. This no longer works.
I discovered a work-around. You can ask it to set a timer, giving it a name without a time, and Google will ask, "How long?" Then, you can give a time. However, at the end, the notification will not announce what the timer is for unless you ask, "Hey, Google, what was the timer for?"
This is all very awkward if you have multiple timers going. You don't know which timer has expired. I don't know why they would change things like this. Alexa's timers are far better. It even tells you on other speakers that timers in another room have ended.
I would think they'd want to make Google Home better, not worse. Another thing they should change is Google confirming every command verbally. Just do the things silently that are obvious. If I tell it to turn off a light, why do I need confirmation? I can tell if the light is off.
Many times, I will use an automation that turns on several things. Sometimes, it will say a light is offline (3 annoying times in a row), yet the light turns on just fine.
I used to be able to pause playback on my Nvidia Shield via voice. This no longer works either. It will say, "Pausing Shield," but it doesn't.
12-02-2025 07:00 PM
Hi TE5LA,
Thank you for your prompt reply. I appreciate all the detailed information.
Based on your answers, please do the following recommendations:
Step 1: Active Routine toggle off and on. Here are the steps:
Step 2: Find the Routine Entry in the Activity tab.
The Google Home app includes information about when and why Household Routines ran, which can help determine the cause of the failure. Here are the steps:
Additionally, please provide the firmware version for your Nest Speaker. Here are the steps:
Please keep me posted.
Byron
12-02-2025 08:35 PM
I don't think pausing and starting applies as I have already created new automations that have the same issue.
The only thing activities show is an automation started "because of a voice command." No more details.
The cast firmware is:
3.77.505721
12-03-2025 11:32 AM
Hi TE5LA,
Thank you for your reply. I appreciate all the information. Let's explore additional options.
Based on your answers provided, please do the following:
Step 1: Do an additional factory reset to the device. Here are the steps:
Step 2: Create a new automation or edit the existing one using different names or similar actions.
Edit the custom routine to give a different name to the starters and actions. Here are the steps:
Byron
12-09-2025 03:26 PM - edited 12-09-2025 03:28 PM
A factory reset is simply touching the top of the speaker for around 10 seconds. You must be thinking of a different product.
Why would just this one automation exhibit this issue when I have more than a dozen that don't? It also contains a power toggle for just two devices, and does not go into this mode if I issue separate voice command for those devices. This must have something to do with the update.
12-09-2025 04:35 PM
Hi TE5LA,
Thank you for your reply. I appreciate your insights regarding the previous steps provided.
I understand about the reset process that you performed. However, there is an alternative factory reset that needs to be tried. Doing these alternative steps can delete all previous data from the device and start from the beginning.
Also let me know if you did the alternative custom automation using a different wording and actions.
Byron
12-10-2025 08:49 PM - edited 12-10-2025 08:49 PM
I figured it out. Google wants to keep removing abilities so users can have a worse experience, like how they removed naming timers.
They also removed allowing voice commands within automations. The automations for the device in question literally had, "Turn off Shield." Well, it isn't allowed anymore. I replaced it with a device control instead of a custom one, and now it works as it should.
I wish Google would stop screwing things up with Home Assistant, but if they are going to change something, they at least inform us.
