SwitchBot temperature sensor not available in automations web script
DavideCap24
I am trying to build automation on the Home Script editor but I can't find a solution to my problem. I have 3 thermometers, connected via Switchbot using the Switchbot hub 1. (both devices are Bluetooth and use a hub to sync to Google Home). On the Google home app I am able to see the Switchbot devices but I cannot select in starters device section in any condition (i.e device.state.SensorState or device.state.TemperatureControl etc..).
Why I cannot simply use a sensor feedback to on/off my clima that is already in Google Home app?
I bought pixel and I sell Alexa to buy Nest, in order to have all Google...but I have this big issue.
Could you help me?
Thanks
AnthonyUK
Would love to know if you ever found a workaround for this.
I want to use SwitchBot Hub 2 to close my curtains if the temperature goes above 24°C, but can't find a suitable state in Google Home Script Editor for SwitchBot Matter.  It just says [device.state.TemperatureControl] is not supported by device  for whatever I try.
