Thermostat compatibility
tfarr
Hello!
I need some help to determine what I need for compatibility here.
I believe the wall controls are just data fed and that the real wiring is attached to the furnace itself in the basement. Looking to upgrade to a smart thermostat from this Honeywell but I am concerned that there may be more than meets the eye with this upgrade.
TIA
zoeuvre
Hi tfarr,
Thanks for posting here in the Community forum and for showing interest with our Nest Thermostats.
Wire labels such as 1 2 3 and 4 indicate a proprietary system. Proprietary systems usually only work with thermostats made by the same manufacturer. But some proprietary systems may also have the option to use standard heating system wires. Contact a local HVAC professional and have them check if your proprietary system can be rewired to be Nest compatible.
Keep us posted. We're here if you have any other questions.
Zoe.
zoeuvre
zoeuvre
Hello tfarr,
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
