Thermostat
dougm840
I just installed a brand new nest thermostat and I'm not getting anything on the dial it's all blank
MelbaDT
Hey dougm840,
Sorry to hear about your thermostat but thanks for reaching out.
What specific Nest thermostat do you have? If it is the newest one with a mirrored display, have you tried changing the batteries? If it's the Nest Learning Thermostat or the Nest Thermostat E, you might want to try charging the display via USB cable. Here's a guide: https://goo.gle/2JgQEwI
Keep me posted.
Melba
MelbaDT
How's it going with your thermostat? Have you had the chance to manually reset it?
Melba
MelbaDT
Melba
