12-29-2022 02:49 AM
I have a routine with two starters and a number of Actions
The starters include
The actions include
The routine works if I say "Hey Google I'm awake"
At the trigger time the routine starts, but nothing is announced. However I know the routine has been triggered as if I go in to edit it it shows it's started.
Google Assistant Activity even shows the command to to play the radio on the Smart Display at the expected time, but nothing actually happens on the display
Anyone else have the same problem or know how to fix it?
12-29-2022 06:30 AM
Ah found the problem...
You can't have a "When I say to my Assistant" and "At a specific time" both as Starters and have the audio assigned to a specific device.
01-04-2023 09:02 AM
Hey Wibbly,
Thanks for updating the Community forum of your resolution — it's a big help! If you have any updates or just a discussion topic, feel free to start a new thread in the community otherwise, we'll lock the thread after 24 hours.
Alex
