Trying to create a smart house
AllsLost
We've tried a new and old Hub, nothing more than 3 years old. We have 2 mini speakers,  1 smart speaker, a camera/doorbell, a security camera, 2 smart lights,  and a thermostat.  We can't get anything to work. We get a lot of "Hmm. There seems to be a glitch." Hub won't do anything, neither will the minis, or the smart speaker.  We've rebooted and factory reset. Help!
Juni
Hi AllsLost,
Thanks for reaching out. What is the distance of your Nest speakers and display from your Wi-Fi router? Are you getting the same response using your phone’s Google Assistant? Try to reboot your Wi-Fi router, and once the network is back on, observe if it makes any difference. Also, if possible, could you try to use another network to isolate this?
Juni
michaks89
If you're experiencing issues with your Nest speakers, displays, or Wi-Fi network, I recommend reaching out to Google Support or referring to the documentation for your specific devices for troubleshooting steps. They can provide accurate and up-to-date information to help you address any technical difficulties you're facing.
Princesss
Thanks for posting in the Community.
For any questions and concerns relating to your Google Nest speakers, feel free to respond to this thread or visit our Help Center. We'd be glad to help!
@michaks89, thanks for chiming in.
Princess
