Turning lamps ON/OFF does not work correctly
kungmats
For about a week now, when I ask Google to turn ON or OFF lights in a home or room, ALL devices turn ON or OFF. So not just lights but also plugs, TVs, etc.
Is the exact command phrase "Turn off lights"?
kungmats
In swedish
"Tänd sovrummet" = (turn on the lights in the bedroom) or if you want (light up the bedroom)
"Släck sovrummet" = (turn off the lights in the bedroom)
If the lights are grouped together in the same Room as the speaker you're talking to then "Hey Google, turn off the lights" should be all you need to say.
Reconnecting the manufacturer's app to the Google Home app couldn't hurt in trying to solve your verbal command issues
kungmats
But that is not the problem. The lamps goes on and off as they should. The issue is that my cooling fans, tv set, and heaters also reakt
