Tuya Door sensor not available to Home Automation
CristianoPC
Hi,  I bought tuya smart sensor for door/Window. I successfully connected sensor to tuya smart app but, and successfully connected tuya app with my Google Home app.
But when I try to create routines for turning lights with options "When device does something" I can't find my door sensor.
Can u help me with this?
Kind regards,
Cristiano
6 REPLIES 6
DWB1973
Contact sensors are not yet available as automation starter devices from within the GH app.  You will need to use the script editor before you will be able to select contact sensors as a starter device.
Tks a lot. Any suggestion how to start in this script? (Sites, video, any specif index? 'google script'?)
Thanks a lot!
Eaw
Found a workaround... You'll need a Tuya smart plug to do so.
Create a scene on Tuya app when door sensor is open it turns on smart plug.
And when door sensor is  closed it turns off smart plug.
Now in Google Home, create a routine with the smart plug as the starter, whether on or off.
Gauthier158
You can do the same thing by creating a virtual device.
tuto: https://thingsboard.io/docs/user-guide/integrations/tuya/
