Use person detection to trigger light, then turn off
kevwags
I’m trying to have my backyard nest cam use person detection to turn on a lamp and then if there is no motion detected for 10 minutes, turn the lamp off. I also have a condition to do this only at night. I cannot get the section that turns off the light to work without errors:
metadata:
name: Backyard Motion Detected
description: When backyard camera detects person, activate living room lamp
automations:
- starters:
- type: device.event.PersonDetection
device: Backyard camera - Backyard
condition:
type: time.between
after: 22:00
before: sunrise
actions:
- type: device.command.OnOff
devices: Living Room Lamp - Living Room
on: true
- starters:
- type: device.event.MotionDetection
state: motionDetectionEventInProgress
is: false
for: 10 min
condition:
type: time.between
after: 22:00
before: sunrise
actions:
on: false
7 REPLIES 7
Cosacalo
I use this script to do what you want to do. You can add more conditions if you'd like.
metadata:
  name: Doorbell Camera Person Detected Light On
  description: Turn on the lights when camera sees someone.
automations:
  - starters:
        device: Doorbell - Front door
    actions:
        devices: Porch Light - Front door
        on: true
      - type: time.delay
        for: 20min
        on: false
    condition:
      type: and
      conditions:
        - type: time.between
          after: sunset+1hour
          before: sunrise
        - type: device.state.OnOff
          state: on
          is: false
          device: Porch Light - Front door
EmptyNester
Gold Product Expert
Gold Product Expert
This is excellent,  thanks for posting!  It works great for me.
One additional question.  Since the doorbells have facial recognition is there a way to make an automation that play a short recording of my voice over the door bell the says "HELLO PAUL" when the doorbell see PAUL?
kevwags
This worked! There is very little latency also which is fantastic. Final code below:
metadata:
  description: When backyard camera detects person, activate living room lamp for 10 minutes.
automations:
  - starters:
        device: Backyard Camera - Backyard
    condition:
      type: time.between
      after: 22:00
      before: sunrise
    actions:
        on: true
      - type: time.delay
        for: 10min
        on: false
blackmagic
@kevwags which lights are supported with the script editor? I have kasa switches that are added to my google home, but I guess those are not supported.
well.. it appears the HS220 switch is indeed supported as an action for on/off, but for some reason the script editor is not recognizing it as a device.
Not sure. I am using a Govee Wi-Fi bulb.
I had to unlink kasa, close the app, and then re-add it!
