12-17-2022 10:18 AM
I’m using the earphone jack on my iPhone 6 to connect to my old analog stereo. I’d also like to use Google Home to stream to my Google Nest hubs at the same.
I could also stream from the Nest to my iPhone.
Any ideas??
12-23-2022 01:10 PM
Hi Gnickada,
We would like to clarify your inquiry. Are you trying to stream music from your Google Home app to your Nest Hubs? If so, You can create a speaker group. Check the steps below on how to do it.
Check this link for more information.
Hope this helps.
Juni
12-26-2022 01:54 PM
Hello there,
Checking back in to see if the troubleshooting shared above helps. Let us know by updating this thread and the Community will be happy to lend a hand.
Alex
12-27-2022 02:58 PM
Hey Gnickada,
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
Alex
