Vibration sensor routine
saeedahmed40
I was wondering if there's any chance of having a vibration sensor where once the vibration stops it can stop a smart plug. Does anyone know if this is possible?
Juni
Hi saeedahmed40,
Thanks for reaching out. I totally understand that this is a good feature to use with Routine, but it isn’t available. I'd suggest you submit feedback about it. See the article below on how to do it.
Share feedback about Google Nest
Juni
