Wakeup light stuck at 3%
sparkles77
Hi - I have written a very simple automation to wakeup my Nanoleaf Essentials Matter Lightstrip at sunrise using the device.command.LightEffectWake action over 5 min duration.  There are two problems.  First - it reaches 3% brightness in less than a minute then never increases in brightness past 3% after that.   Second - occasionally the strip will start at 3% then briefly dim to 1% before increasing again to 3%.   I can manually set the light to brightness setting up to 100% from the Google Home App with no problem.
In addition to the two problems above is there a way to define the target brightness setting for wakeup in the YAML script?
thx!
0 REPLIES 0
