Wifi connection
Pokey112
INTERNET COMPANY CHANGE THE ROUTER,WITH NEW WIFI, UNABLE TO CONNECT THE GOOGLE NEST HUB & MINI SPEAKER TO THE WIFI, I HAVE TRIED EVERYTHING
@Pokey112
Since updating Wi-Fi settings for Google Nest devices can be problematic, Google Nest's first recommendation is to set the network name (SSID) and password on your new router/modem to the same values used on your old router/modem.
If you can't do that, then the basic process is to remove the Google Nest device from the Google Nest app or Google Home app while still on your old Wi-Fi network, do a factory reset, and then reinstall while on the new Wi-Fi network.
https://support.google.com/googlenest/answer/10165378
lagend
Ensuring a great user experience on your website can result in higher engagement metrics, including longer dwell times and reduced bounce rates, which may have a knock-on effect on your search engine rankings.
Keep in mind that off-page SEO should support your on-page initiatives, which center on improving the technological, contental, and structural elements of your website. You may improve your website's chances of appearing higher in search engine results and drawing in more organic visitors by combining both on-page and off-page SEO tactics.
LovelyM
Hello everyone,
Thanks for your assistance, @MplsCustomer
@Pokey112, thanks for reaching out. Have you tried the troubleshooting steps that MplsCustomer suggested? That should help get your Google Nest Hub and Google Nest Mini connected to your new Wi-Fi network, but if you are still having issues, let me know so I can further help.
Lovely
LovelyM
Hi Pokey112,
I want to ensure you are good to go. Please reply to this thread if you still need assistance so I can give you a helping hand.
Sincerely,
Lovely
