Wire door bell
Rudyglez
How do I reinstall Google home and nest app. Thanks
@Rudyglez
I'm not sure what problem you are trying to solve, but to reinstall either the Google Nest app or the Google Home app you just delete the app on your phone or tablet, and then go to the Apple App Store or the Android/Google Store and reinstall it, and log back in with your same credentials.
Alex_S
Thanks for the help, @MpIsCustomer.
@Rudyglez, I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Alex
Alex_S
Hello Rudyglez,
I'm checking in to see if you still need help. Please tell me if you have other questions or concerns. I want to make sure you're all good now.
Alex
