04-22-2023 06:16 PM
My Wyze caneras appear on the google hub but when I click on the camera it says offline. I immediately go to the Wyze app and the cameras are working just fine.
can someone help get my cameras to work on the google hub.
04-26-2023 12:21 PM
Hello Craigc,
Thanks for reaching out. We'd love to help.
Please answer the following: were the cameras working before? If yes, when did the issue start? Were there changes made? What troubleshooting steps have you tried?
Please unlink and then relink your Wyze xameras from the Google Home app. Here's the guide: open the app > Tap Settings > Look for Works with Google > Select Wyze > Unlink. Do the same steps to relink your devices. Once done, ask your Google Nest Hub to 'sync the devices' and then confirm if you can now stream on the display and app.
Keep me posted.
Lovely
04-26-2023 12:30 PM
They were brand new cameras that I was setting up. Once I completed the Wyze set up, I then linked my Google Home App to the cameras and that is when I came across the issues. I have unlinked/disconnected the Wyze cameras from the Google home app and reconnected/synced the Wyze cameras to the Google home app and still get "can't reach this camera" from two cameras and "camera off line" from another camera and this message is being shown in the google home app.
Craig
04-29-2023 11:07 PM
Hey Craigc,
Chiming in to ensure everything is covered here. Please proceed with resetting your Google Nest Hub by pressing and holding both volume buttons together, at the back of the Nest Hub, for about 10 seconds. You'll hear your Google Assistant confirm that it's resetting the Nest Hub.
Keep us posted.
Muddi
05-01-2023 08:28 AM
Resetting the hub worked. I can now see live images for the cameras. This trick worked. Not sure why the rebooting of the device didn’t work. Thank you.
05-02-2023 10:26 AM
Hi Craigc,
Wonderful — happy to hear that factory resetting your Google Nest Hub resolved the issue! Thanks for keeping us in the loop. Let me know if you still have questions or concerns; otherwise, I'll be locking this thread after 24 hours.
Kind regards,
Lovely
