12-09-2025 01:09 PM
How do I change from Celsius to Fahrenheit in the Google home app. The correction is not on the thermostat. It is in the app, I just don't know how to set it up.
12-12-2025 03:24 PM
Hello Larry33,
Thank you for reaching out. I understand you are looking to switch your thermostat's temperature display from Celsius to Fahrenheit within the Google Home app. I'll be happy to share more details with you about this.
After checking some information, let me tell you that at the moment we don't have the option to change the temperature display from Celsius to Fahrenheit on the Google Home app. But, since your device works with Google, you can control the device by using Google Assistant.
I hope this information helps.
Jenny
