Z wave 2 module and conexis L1
Bran1977
Hi
I just installed z wave 2 module in my conexis L1 lock and its seems like your product is not compatible with this module
Please help
Bran
6 REPLIES 6
sporfrog
I am not sure I fully understand what you are asking.  However in general, a Z-Wave device connects to a Z-Wave compatible hub.  Then that system, if supported, can be integrated into Google Home.  A Z-Wave device without a hub cannot be directly connected to Google Home.
Do I need a hub to connect my conexis L1 (with already installed zwave2) with my phone?
Full disclosure - I, personally, am not familiar with a "conexis L1".  Your question might be better answered talking to that manufacturer. However, generally, as noted, a Z-Wave device will connect to a Z-Wave hub.  All the Z-Wave devices in a home connect to the hub.  What you can do with that hub is dependant on the hub you have.  The hubs, in turn, connects to the internet and allows a user to manage devices connected to it via a mobile phone.  Also, most hubs allow for integration into voice enabled service like Google Home.
Ok, I understand situation. There is no WiFi connection without compatible hub iz it z-wave2 or not
Thanks a lot
GarrettDS
Just wanted to hop in here to see if we still needed help on this. Thanks to sporfrog for the help here. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Have a great day.
Garrett DS
GarrettDS
Have a great day,
Garrett DS
