connecting Litemate wifi lights to google home
MarietjieP
good day I am trying to find out if the LIFEMATE WIFE LED LAMP is compatible with the google nest hub 2nd generation?  In the package of the globe it says google android compatible but when I am trying to connect it to my google home app its not picking up the lights.  Can anyone assist please?
Alex_S
Hi MarietjieP,
Thanks for visiting the Google Nest Community. We have limited information on third-party Google Assistant-enabled devices. I suggest that you contact the manufacturer for further information if your Lifetime Wife LED Lamp works with Google. They can inform you of the application you can use to link it to the Google Home app.
Let me know if you have other questions.
Alex
