rotation du lacht
sined
j'ai installé ma serrure nest yale et pour le veroullage la rotation ce fait par la gauche au lieu de la droit , allors comman changer la rotation.
Merci
janthadeus
Hi sined,
I'm sorry for the delay. It looks like your deadbolt isn’t calibrated. When you’re installing your lock, the Nest app will have you check the deadbolt’s calibration. Your door needs to be closed during this step. If your door was open, your lock may not be able to properly calibrate.
Without accurate calibration, the Nest app may say that your door’s locked when it’s not, or vice versa.
Here are some troubleshooting steps to try:
  1. Open your door.
  2. Slowly use the thumb turn inside your home to extend the deadbolt all the way to the locked position, then retract it back to the unlocked position.
  3. Close your door.
  4. Again, use the thumb turn to extend and retract the deadbolt.
  5. If all else fails, factory reset your lock.
If it feels like the deadbolt is sticking or scraping at any point, or if it feels like the deadbolt isn’t able to fully extend when your door’s closed, you may need to make some adjustments.
aatienza
I appreciate the help, JT.
Archie
aatienza
Hello there,
Archie
