06-01-2023 04:41 AM
hi all
Im hoping someone can help me out with automatons in GH
Im trying to get aqara fp2 ( presence sensor) to talk to either Homeseer (HS4) or Hubitat 8 with a simple presence/no presence
My steps
Set up a switch. in Homeseer...gave it a name and a room...simple on/off switch
Set up GH services to see Homeseer and this switch
GH can see the switch..I can press the Google home icon of this Homeseer switch in GH instant change in Homeseer (on/off)
So far so good
I then set up a household routine in GH
The first
Starter: when a device does something
I select "if presence sensor fp 2 detects motion"
With conditions: anytime anyday
Action: switch turns on
The second
I select if presence sensor fp 2 detects no motion for 1 minute
Action: switch turns off
This is where I'm expecting this to just "work"..
But. No
If I go to in GH household routines and press the run command..it works.. switches as required
But it's just not running automatically
I have no idea why..
Any help will be greatly appreciated
im located in Sydney Australia...
06-05-2023 02:43 AM
Wow ...it appears that I'm the only one to have this issue
09-01-2023 03:30 AM - edited 09-01-2023 03:31 AM
Similar here. Mine will turn on but not off. The activity for on and off shows in the Home ativity feed, but the card does not go from on to off. If I click it Homeseer responds just fine.
TJ
09-02-2023 02:06 AM
Wow.. only 2 people in this world have this issue
09-02-2023 04:46 AM
As of yesterday my activity logs look a bit different. When the sensor becomes inactive, I see an inactive in the log immediately followed by an active. I guess this would result in the card and homeseer device remaining on. From these latest logs it probably a sensor bug.
09-02-2023 01:53 PM
I've given up on GH..for any automation
For the aqara fp2 I'm now using
Works perfectly with HS4
