10-12-2023 01:10 AM
I am trying to develop some basic automation routines within google home. I am using the web based script editor.
When i create a routine that works off a switch for example the routine works fine. However i am trying to start it from the humidity sensor in the nest thermostat. my example is below.
automations:
starters:
- type: device.state.TemperatureSetting # Handles temperature points and modes of a thermostat device. # Handles temperature points and modes of a thermostat device.
state: thermostatHumidityAmbient
greaterThanOrEqualTo: 71
device: Hallway(Hall) - Hallway
condition:
type: time.between
after: 07:00 # HH:MM (24 hours format). Adjust time as needed
before: 21:00 # HH:MM (24 hours format). Adjust time as needed # HH:MM (24 hours format). Adjust time as needed
actions:
- type: device.command.OnOff # Turn the device on or off.
on: true
devices: dehumidifier - Front bedroom
Now if i click the run routine button it all works fine but it wont automatically start. Could someone please explain why?
10-19-2023 05:39 AM
Hey @Andybrad - does the automation run if you remove the conditions? That's the first thing I'd check to see if your humidity starter works and your automation isn't being blocked on the conditions you added.
10-19-2023 06:44 PM
metadata:
description: Scripted automation
automations:
- starters:
- type: time.schedule
at: 00:00
actions:
- type: time.delay
for: 00sec
# # Start your script below # #
- starters:
- type:
actions:
- type:
10-20-2023 05:17 AM
Hi, Thanks for the responses.
I removed the conditions and it did work for several days. Its then stopped...... i dont know why
