01-18-2025 06:19 PM
Hi all i hope in posting this in the right area. I have had google nest 3 pack for 3 years now. Lately with lots of drop outs. At least 5 dropouts a week. I decides to factory reset everything including my app and profile and start fresh.
I'm having a really frustrating issue when I connect the wifi point to the nest router and it gets to the end when it's adding it to the wifi network and just stays there for ever. Can anyone help this has beat me. 3 hours in I'm asking for help before I go buy a new system.
02-19-2025 11:40 AM
Hey everyone,
Thank you for your patience. This issue has been fixed alongside the release of Google Home app 3.29, all users should have received the update by now. If you're running a different version of the app, double check for updates in the Play Store and try restarting your device. If that doesn't fix the issue for you, please let us know in a comment below.
01-20-2025 07:34 AM
I have had the same system for the same amount of time, started having the same issues, and then took the same actions. Is there a Google accounts issue ongoing? I managed to set up the router again, but both of the nest wifi points are stuck as "adding wifi point to your wifi network"
01-20-2025 04:11 PM
I'm having this exact issue. I can get my routers both up and running but cannot get the wifi points back on. Keeps getting stuck at "adding wifi point to your wifi network". This is very frustrating!
01-21-2025 01:12 AM
I have had a 2 nest pack for two years without any issues. Yesterday I changed Internet providers so I had to do a full reset. Now I have the exact same problem where the wifi points get stuck at "adding wifi point to your wifi network". Has anyone worked out a solution?
02-15-2025 05:33 AM
Same here. No problems last few years new internet provider started over now they will not connect. Routers connect fine. wifi points no dice
02-15-2025 05:52 AM
It was fixed today with the rollout of the latest Google Home app. It should have been fixed far sooner, but it's fixed now.
01-21-2025 03:01 AM
I have exact same problem starting yesterday - 20th Jan 2025. Factory reset of network that's been working for years.
I have been trying the workarounds documented here but with no success. 5+ hours burnt on this so far.
https://www.reddit.com/r/GoogleWiFi/comments/orbywv/nest_wifi_access_points_failing_setup/
thanks in advance
01-21-2025 03:13 AM
I called Google support twice today. First suggestion was a waste of time, and the second call I spent over 1 hour trying different things I had already tried, and no success. He said he would respond with a solution in the next 12-24hrs, but might likely be a replacement of my wifi points. I told him I didn't want the just a replacement, as it's likely to do it again, seeing both my points failed together! I have a feeling google has done this purposely to push everyone to buy their newer versions. I only bought this system 3 months ago, so will be asking for a refund it if the devices are no longer supported. And yes, I have also spent over 6 hours on this now, ridiculous 😑
01-23-2025 03:58 AM
This was there response, after I sent them a receipt of their Google products from the Catch website:
"Unfortunately, after a thorough evaluation, our senior support team has determined that the best course of action is for you to contact the third-party retailer where you originally purchased the device. They will be able to assist you with a replacement or other appropriate resolution."
😠furious that now I'm going to have to try now explain all my issues again to another third party, that will likely point back the blame to either Google, or if not my Internet provider!! This is not right!
01-23-2025 06:31 AM
As I bought my WiFi point from the Google Store they can't use this excuse on me. I spoke to Tech Support yesterday and they acknowledged that they'd discussed the same problem the day before. It sounds like it's a known problem which, hopefully, will mean it should have a resolution... eventually.
Is it my imagination, but have Google WiFi products become very flaky recently?? After factory resetting and re-adding my Google Hub, it worked fine... before telling me to "link it to my Google account"? I only had to do this after deleting an recreating my Google Home... to try and sort out other Google network issues. FFS.
01-21-2025 06:51 AM
Changed ISPs and went back to using my Google Nest Wifi Gen2. I am in the process of buying a house so I bought a Gen 2 Access Point recently as well. Brand new, everything connects, the access point connects to my router/wifi but also is stuck at "Adding Wifi point to your wifi network." I have done hard resets, factory resets, pulled the power cable for 10+ minutes on both devices with no success. Any recommendations would be greatly appreciated.
01-21-2025 07:22 AM
Just spoke with Nest Support and found out based on my serial #, my ap was for the country of Australia. Solution: Exchange the ap at Amazon, which I bought from the Google Store, and request one that is for the USA. Stay tuned.
01-21-2025 11:47 AM
Yep. I have precisely the same issue. I've tried factory resetting the device, probably 6 times now. Nothing I can do progresses any further than "Adding Wifi point to you WiFi network" when it then hangs.
This and my Nest router dropping connections every few minutes makes me hate Google, with a growing passion.
01-21-2025 05:14 PM
I spoke directly Google today and it's a known issue with no resolution, the problem has been around for about 2 weeks. Now I guess I sit tight and wait for a resolution,..........
01-21-2025 11:38 PM
Thank you for letting us know 👍
01-22-2025 01:44 AM
I used the request a call back in the help feature. The were super helpful and gave some things to try but didn't work. What they also requested was the model and software version.
01-22-2025 02:51 AM
Oh, I can't fault the willingness of the support staff to help, but I do fault the engineers allowing it to happen in the first place. There's a bug in the latest version of their Google Nest WiFi router causing it to drop connections, often several times an hour. This has been happening since October and yet there's no public acceptance of the issue nor an eta for resolution. The problem with the WiFi point is just another thing.
01-23-2025 06:36 AM
Google Nest WiFi router dropping connections?? Yes! You can watch the status light pulse for a few seconds before stabilizing at solid white. In the meantime, your Teams call has frozen, your download has failed and your WFH Citrix connection hung... before reconnecting. It has been happening for a few months now and I've only just started doing something about it. Report it! ...and go through the process of deleting your Google Home, resetting everything... and it make absolutely no difference!!
01-26-2025 02:00 AM
Bonjour, j'ai le même problème que vous tous c'est inacceptable
Je vous propose de faire l'enquête de satisfaction en très insatisfait
01-23-2025 03:34 PM - edited 01-23-2025 03:36 PM
Good to know I'm not going crazy and other people are experiencing this too.
I've changed my ISP a few times before and annoyingly I've had to do a reset in order to input the new WAN details (because of the other long known issue where the WAN details won't save). Every other time I've changed ISP, the two other wifi points have connected with no issue. Now I'm getting through to the 'adding wifi point to your wifi network' and it just hangs indefinitely. I've tried:
- resetting my whole network (including the modem and the points)
- power cycling all devices
- uninstalling and reinstalling Google Home
- using Google Home on a different device
Nothing is working, This is hugely infuriating.
01-23-2025 03:50 PM
I followed up Google again today and got the following reply. It doesn't look good.
Thank you so much for following the previous steps, right know just to let you know that this is currently an on going issue right now our engineering team is working on it and being investigated for a fix. The process could take some time, our team will let you know when the issue is fixed, because it is an issue most related with a bug in the Google home app, so we need to check the software of our app. Thank you so much for all of your patience and trying to troubleshoot, we will let you know immediately when the issue is fixed.
01-23-2025 04:56 PM
I think I've come up with a workaround thanks to your message!
When I've been trying to setup my network/wifi/points, I've been using Google Home on my android device. Your message made it sound like Google knows there's an issue with their Home App, so I figured chances are this is likely to just be in the android build.
So I downloaded Google Home to my iPad and signed in, did a factory reset on all my devices (the router and two points) and went through the connection process on the iPad....and it's all worked! There was no issue connecting the wifi points to the mesh!
YMMV, but if your issues are through Home on an Android device, and you have an IOS device, I suggest giving it a go on IOS.
01-23-2025 05:58 PM
Thanks for the advice, iPhone for the win.
I setup using the home app on a iPhone and everything is now working.
How dumb that google apps do not work on google devices !!
01-27-2025 10:12 AM
Confirming this worked for me as well - using an Apple device vs a Samsung. Thank for finding this solution.
01-23-2025 07:20 PM
Thanks! Worked for me on my iPad Pro. Was going nowhere with my Google Pixel phone. The irony.
01-23-2025 07:25 PM
Oh my goodness. How embarrassing. Well, I'll be here waiting for Google Home to work on Pixel...
01-27-2025 01:43 PM
Oh man, you're lucky!
I've been having problems with my pixel and my wife's in so so I decided to use my iPad and my daughter's iPhone. I get the same problems with all of them. Google home app having an issue connecting and can't get the google Wi-Fi to reconnect
02-01-2025 09:43 AM
SPOT ON!
Google is pathetic now. I have wasted hours and hours on my GOOGLE PIXLE phone, trying to get my GOOGLE HOME network fixed since last weekend, when all I needed was to fire up my old IPHONE to fix their problem.
do better google
01-27-2025 01:42 PM
This is starting to align with the issues and the responses that I'm getting. I started seeing some glitchy **bleep** happen January 16th. Google home was not working. Then access points started dropping out sporadically. **bleep** me go through all of these resets. Do the factory reset and now nothing would connect. Spent about 4 and 1/2 hours on the phone with Verizon and Google today and still no resolution.
I did find out that the newest puck out of the four that I purchased, it was an add-on, that's the only one that I can get connected at all. All of the original ones can't connect in any form. They worked for over 5 years and now they don't. And Google denies it's an update. Hey, are telling me the ISP router needs to be disabled because there is an IP conflict. I changed the IP addresses on the router and it still doesn't work.
01-26-2025 02:01 AM
Je vous propose de faire l'enquête de satisfaction en "très insatisfait"
01-23-2025 07:28 PM - edited 01-23-2025 07:56 PM
I am having the same issue, when attempt to "Add" a new Point in the Google Home App the Nest Wifi Point is stuck unending on "adding wifi point to wifi network." This unfortunately happened AFTER I tried the Nest Wifi PRO three pack, which was somehow slower than the Nest Wifi Gen2, so I was switching back to the Nest Wifi Gen2 (non-Pro). I tried on my Pixel 9 and Pixelbook, same issue. If Google doesn't fix this soon, I am leaving the Nest Wifi platform and will go with another mesh provider. Ugh.
01-24-2025 08:37 AM - edited 01-24-2025 08:38 AM
I just got mine to connect!
I'd been trying for days!
I read a comment about ios working, and I thought that maybe it's the version of google home.
I found an old phone hoping it would have google home on it, it didn't.
So I was desperate, and went and downloaded an old version of Google home and installed it on my old phone. and was able to add the AP!!! it's not the safest solution, but It added the AP in just a couple minutes.
I then turned off my old phone.
if I was to do this on my only phone, after adding the AP, I'd removed the sideloaded home and put the official one back on.
01-24-2025 10:30 AM
Same result here. Doesn't work from Android, works fine from iOS.
01-25-2025 06:15 PM
Adding to chorus. Worked on iPad.
01-24-2025 03:26 PM
I guess I'll look for an old iPad or something to get it to work, pretty stupid all of a sudden android devices can't work with google home. Seems upside down and backwards to me . I have in the meantime gone out and purchase a new eero6+ mesh system 10x better than my old nest system. No dropouts and more speed with better range .
01-24-2025 03:41 PM
I side loaded an old home app, and it worked. Put the new one on once I added the AP
01-25-2025 07:04 PM
I tried using Bluestacks to add it but that didn't work and I don't have an iPad. Then I remembered a Pixel 2XL I have not turned on since 2022. I fired it up and added the access point in 3 minutes.
01-26-2025 09:57 AM
I have the same issue:
Our internet was slow and broke all the time, so I decided to switch to a new ISP.
I reset my Nest Wifi points and router.
I could set up the Nest router but the Wifi points would not work.
After trying several different configurations, I found this thread. I used an older version of Google Home (3.10.1.6), and the setup worked fine.
This sounds like a Google Home App issue?
01-27-2025 10:23 AM
Yes, you need another method to access Google Home. Some have used iPads, I used an old phone that didn't have the latest version of Home. I'd tried every other avenue from Bluestacks to canceling the installation and the cycling the power and pick it up in the middle but none worked.
01-27-2025 05:05 PM
Just a heads up for anyone that runs into this, side loading the December version of the Google Home app helps with finally setting up the extra wifi points . I was struggling with this for 2 days and no luck. I ran into someone posting that side loading might help. Give it a try (APK mirror) and it might help you
