01-18-2025 06:19 PM
Hi all i hope in posting this in the right area. I have had google nest 3 pack for 3 years now. Lately with lots of drop outs. At least 5 dropouts a week. I decides to factory reset everything including my app and profile and start fresh.
I'm having a really frustrating issue when I connect the wifi point to the nest router and it gets to the end when it's adding it to the wifi network and just stays there for ever. Can anyone help this has beat me. 3 hours in I'm asking for help before I go buy a new system.
02-19-2025 11:40 AM
Hey everyone,
Thank you for your patience. This issue has been fixed alongside the release of Google Home app 3.29, all users should have received the update by now. If you're running a different version of the app, double check for updates in the Play Store and try restarting your device. If that doesn't fix the issue for you, please let us know in a comment below.
01-27-2025 05:08 PM
Where do I get it? Gotta link?
01-27-2025 06:00 PM
This is the one I used.
I know nothing about this site.
https://chromecast.en.uptodown.com/android/download/1021204873
but it worked for me.
01-28-2025 05:16 AM
Thank you for posting.
I tried version 3.28 from November but didn't work.
I will try this one when I get back home later this week.
01-29-2025 08:55 AM
Thank you so much for this! Installing this finally resolved the issue.
01-30-2025 06:09 PM
You're welcome. The idea crossed my mind since it worked on iPhones. Made me think it was a software problem
01-30-2025 01:39 PM
Thank you Tjarrard. I un-installed my current Home app and installed the one you listed and using the older Home app version on my s24ultra, both my points are connected to the WiFi network now. 👍
01-30-2025 06:08 PM
Great! Now it's connected, I'd put the current version back on.
01-30-2025 02:19 PM
Thank you so much Tjarrard, the link you posted fixed it for me and it was a huge help to get things back up. Hopefully the Google engineers will fix the Home App with the next update so we don't have to use work arounds.
01-30-2025 06:07 PM
Glad it worked for you!
a week ago
Happy to report that the latest update really does fix this issue (version 3.33.45.2). Finally 🎉
Monday
Nope. “Adding WiFi point to mesh network” or however it’s worded just spins and then fails.
01-27-2025 05:09 PM
Hey everyone, I took the suggestions above to try & connect the Wi-Fi point via a different device (Android vs Apple iOS). After numerous tries to set up the wifi point (not the router), using my Android pixel 9, it failed every time. After reading this discussion, I tried setting it up via my iPad & it connected first time with no issues.
Obviously this probably won't work for everyone because not all of you own both types of devices, but if you do have both devices, use that method for now. Good luck!
01-29-2025 11:50 AM
Yes, thank you for the IOS suggestion, finally got my points to connect successfully!!
01-31-2025 04:35 AM
Bought a 2 pack nest router with point and same issue gets stuck forever adding point to wifi network. I have had to set up home app on partners iphone and then send invite from pixel 8 home app and then went through the add wifi point through the iphone and it got the set up done then it shows up in my devices on pixel 8. So this obviously is a google issue and needs sorting out asap, unacceptable when I spend what i call a large amount of money on this mesh . 3 hours near enough to sort this out.
01-31-2025 11:24 AM
Thank you to everyone who has reported an issue with adding Nest Wifi Points through the Google Home app on Android. Our team is aware and actively working on a fix. We'll keep you updated once a fix is on the way, we appreciate your patience in the meantime.
01-31-2025 12:24 PM
Just a few minutes ago I supplied detailed email with all the screenshots of all my settings.
From my experiences, appears that the Wi-Fi access points were upgraded around January 10th and now they don't work at all for me.
Three of them are the original first generation. One is still Google Wi-Fi but a newer version. This newer one is the only one I can connect to get be a router. The other three don't work at all. And even still with this one connected as the router, Google home is still losing its connection and this router is hiccuping and disconnecting a couple of times an hour for a few seconds. This is the initial symptom that I had starting around January 10th where Google home was showing. My Wi-Fi access points were dropping. Now that Wi-Fi is gone in most of my house, I've used ethernet and now I'm experiencing these frequent drops.
When I use my Verizon router and not the Google Wi-Fi, I don't have any issues.
Have also deleted my Google home app and reloaded it several times. I've even loaded the December version and the November version 3.20. none of those home apps work to get the Wi-Fi access points working.
Therefore, I come to the conclusion it has to be the the software upgrade to the Wi-Fi access points.
02-02-2025 05:32 PM
Has this issue been resolved yet?
02-02-2025 06:56 PM
so far, just the 2 work around. use an I-device, or side load and old version of Google Home (August 2024 I know worked.
02-03-2025 03:00 AM
No
And for some reason, the workarounds don't work for me.
02-04-2025 06:51 AM
We need an update and immediate fix on this , this is not acceptable when it was raised 2 weeks ago. !
02-06-2025 09:17 PM
When are we expecting the fix. Otherwise I can return the device
02-07-2025 12:23 AM
Tried using an iPhone with the Google Home app and it finally worked.
Issue lies with Android unfortunately
02-07-2025 03:07 AM
Still waiting for a fix, week later and unacceptable on your silence on this urgent problem !
02-08-2025 07:43 PM
faridghar (Community Member) posted a new reply in Home Automation on 02-08-2025 01:23 PM:
Re: stuck forever on adding wifi point to wifi network
Installing Google Home 2.59.1.9 from manually downloaded APK worked for me.
02-07-2025 09:16 AM
Do you have an ETA on a patch to resolve this issue. It appears that this is a wide spread issue impacting a core demographic (people entrenched in the Google/Android/Nest ecosystem). The logical move here would be to prioritize a patch. Is there a communication plan in place to generate goodwill with your userbase? This is basic product and program management.
02-15-2025 09:10 AM
At this point, I think every impacted user should start reporting this to the Better Business Bureau and start the process of finding the contact information for the Product Owner, Program Manager, Architect and Engineer for this product and directing our feedback to the specific people responsible for this issue. This is unacceptable customer service.
02-16-2025 09:57 PM
I did a factory reset on the router and installed the latest Google Home app and I am now about to use the device.
02-08-2025 03:00 AM - edited 02-08-2025 03:01 AM
"In the meantime folks, please move you home office (or actual office) within 5m of your router. We understand this defeats the point of purchasing our expensive wifi extending solution! 🙂 If that isn't possible, please drill holes throughout your home or office to accommodate lengthy ethernet cables. I'm afraid we cannot advise in either of these scenarios (which risk voiding your warranty) nor can (or will) we share with you how long our 'fix' will take to roll out. Have a totally awesome week!" - Google
02-08-2025 02:14 PM
What about same problem with iPhone home app?
02-08-2025 04:11 PM
It is ridiculous that this hasn't ben fixed yet
02-08-2025 05:22 PM
Thanks to BigMac88. It worked as you suggested with the Home App version 2.59.1.9.
Why don't you inform and update and guide this temporary fix to your support staff and as a solution until the proper fix instead your support staff were misleading this issue related to the ISP modem. So disappointed,
02-08-2025 06:29 PM
Is this issue resolved yet ? I spent last 24 hours trying to get this sorted.
How can i get a update when its done ?
02-08-2025 07:42 PM
Thanks . It worked as suggested with the Home App version 2.59.1.9
02-09-2025 10:38 AM
The Google support person said the Verizon router is the problem. I completely removed the router and still getting the same issues.
When is this going to be resolved?
02-10-2025 02:01 AM
1
02-11-2025 12:04 PM
Asking once again , there are too many people having the same MAJOR issue with your product adding points to network that are rendered unusable . Now where is this fix and more so the lack of communication from Google ?
02-14-2025 02:01 AM
You posted this 2 weeks ago and still no **bleep** solution I want a bloody refund. This is complete bull**bleep**. Give me a refund or chucking all my Google hardware in the bin and moving to Amazon
02-14-2025 09:52 AM
I just got the 3 pack from Amazon yesterday and I have the SAME PROBLEM - Ready to send it back to Amazon if someone doesn't GET IT WORKING!
YOUR SHIPPING OUT JUNK THAT DON' T WORK!
02-14-2025 10:04 AM
I see this post was from 2 weeks ago - I'm not gonna wait for you - it's going back to Amazon and I probably won't try anymore of your JUNK!
02-02-2025 06:50 PM
Apparently only if you use an apple device, pretty counter intuitive if you ask me for a google product.
