4th gen Thermostat true radiant has no max duration options
Exempt
Hi...all previous nest thermostats had early on (forced hot air) and true radiant (radiators). Both had options for max duration for how many hours the heating system would turn on to reach scheduled tempature at scheduled time.
With the new google home app true radiant only has a on/off toggle switch. There are no max duration options (start heating 1 hour, 2 hour. Etc.)
Also, i installed correctly and radiator and propane options were selected. Google home app selected early on and has max duration options. It did not engage radiant option.
It almost appears that early on is now used for both forced hot air and radiator systems and true radiant is more of a shut heating down early as to not overheat home. Throughly confused. Does any one know what is going on and can help. Thanks in advance if you can...mike
catheryn
Hello @Exempt
Thanks for bringing this concern to our attention and posting it in the community. I apologize for the inconvenience you're experiencing with your Nest Thermostat when setting heating times in the Google Home app.
I understand that your main concern is that the absence of maximum duration settings for True Radiant mode makes precise scheduling difficult, which can lead to potential overheating issues. Let me help!
Before we troubleshoot, please share the following information:
  • What type of Nest thermostat do you have?
  • When was the Nest thermostat installed?
  • When did the issue first occur?
  • What is the make and model of your HVAC equipment?
  • Is there a preheating message on the display?
Once you share this information, I'll provide the appropriate steps to resolve the issue.
Catheryn
Exempt
Nest gen 4
6 weeks ago
When I added the thermostats to google home app
US boiler company x-205 gas fired boiler...this boiler worked fine with gen 1 and 3 nest software thermostats
Yes
Exempt
Actually what i want to know is why true radiant does not have max duration options the early on has and every other version of older nest software also had.
catheryn
Hello @Exempt
Thanks for your response.
We hope the information provided in this article, True Radiant, will be helpful. It offers detailed guidance and troubleshooting tips.
Please don't hesitate to reach out if you need further assistance or have any additional questions. We're here to help.
Catheryn
Exempt
No it doesn't. And you never even attempted to answer my question. With all due respect, my attempt to get an answer to this question from 4 different reps has been the most incompetent I have ever witnessed from a major company. I returned the 3 thermostats and moved to ecobee thermostats. In three days, they are more accurate in schedule than the nest was after 7 weeks. I will never buy a nest thermostate again...
