Adding the hot water menu to the home hub
Smiffy1
It would be great to have the hot water memo on my home hub max. It's really convenient to have the heating controls available on the home hub max as it gives quick access to the thermostat temperature but there isn't any access for the hot water! It would be great to give the menu so that you could boost the hot water for a set period of time when someone realised there's no hot water in the tank. Gemini voice support would also be great
JuanCH
Hi Smiffy1,
Thanks for reaching out to the community! I understand you'd like to see hot water controls integrated into your Google Nest Hub Max, similar to how your heating thermostat is currently accessible. You're finding the thermostat controls convenient for quick adjustments, and you'd like to extend that functionality to your hot water system. Specifically, you're looking for a menu option that allows you to boost the hot water for a specified duration, especially when you discover the tank is depleted. You're also interested in voice control functionality for this feature. I'm here to help! To gather some more details, I'd like to ask the following questions:
Keep me posted. I look forward to your response.
Juan
