12-11-2023 11:29 AM
First post on this forum, so please excuse any breaches of etiquette. I have our thermostat heating to 17c while at home. I would like the thermostat to drop to 16c when the thermostat switches to Away. Both 17c and 16c are eco temperatures, but I cannot get the unit to drop to 16c while switched to away. Any ideas on how to do this would be greatly appreciated!
12-15-2023 08:22 AM
Hi ANOakley,
Thanks for reaching out to us. To achieve the desired temperature change when your thermostat switches to Away mode, you can follow these steps:
Once you've completed these steps, your Nest Thermostat should lower the temperature to 16°C when it switches to Away mode. When you return home and the thermostat detects occupancy, it will switch back to your desired temperature of 17°C.
Let us know if that helps.
