Best settings for nest thermostat
GraemeFranks62
Hi anybody know the best settings for this thermostat as its now driving me crazy I have moved the thermostat from conservatory to lounge as my last question was answered on here thank you
Jhonleanmel
Hi GraemeFranks62,
Here are some tips to help:
  • Nest Thermostat should be in a room that’s used often so that it can read the right temperature, can sense when the home is empty and know when to automatically turn down the heating.
  • It should have a clear view of the room.
  • Wall-mounted thermostats should be installed on an interior wall. Make sure that it’s away from droughts and heat sources.
  • For zoned systems, install the thermostat in the zone that it’s controlling.
Mel
I wanted to check in and see if you managed to see Mel's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
