a week ago
I'm migrating from v1.0 legacy Nest thermostats. Because of the configuration of my house (it was built around 1850), I have two thermostats, one for the A/C, and another for heat. They are never both in use at the same time. It would be great if I could hook both of the temperature sensors up to both of the thermostats. Is that possible?
a week ago
Nope, the temperature sensors can only be paired to one thermostat at a time.
With the Learning Thermostat, you can combine two separate thermostats to work with it.
