09-12-2021 12:09 PM
My thermostat won't link to my wifi anymore, I used to be able to use the app but have been unable to for a long time now. The thermostat would work properly, adjusting temp as I changed it and now it says it needs to charge or it needs to shut down. I can't get it to stay on long enough to fully troubleshoot it. Any suggestions? Known issues?
09-15-2021 10:34 AM
I am having the exact same issue. There has been no wifi connection for 9 months+, and yesterday night it shut down completely. I charged via USB for 4 hours, but when I put it on the base, it keeps saying it needs to charge & immediately shuts down. I also plugged into my computer, as I saw a Nest post that advised doing this--it does load/show up on my computer when I do this...but I am not sure if that's good or back. I have a C wire & none of the wires look like they have any visible issues/reduced integrity. I am at a loss as to what else to do - and it's 90 degrees in my house right now 😞
09-24-2021 01:39 PM - edited 09-24-2021 01:40 PM
Hello Lauren_T,
Thank you for your patience with us! We've created a case for your issue to send to our support team. Be on the lookout for an email from us in your inbox soon. For reference, your case number is 6-3504000032060.
Kindly,
Ai
09-17-2021 11:33 AM
Any updates from google on this? I’m having the same issue, won’t connect to WiFi and won’t keep a charge. Thanks
09-24-2021 01:50 PM
Hello KatieF,
Thank you for your patience with us! We've created a case for your issue to send to our support team. Be on the lookout for an email from us in your inbox soon. For reference, your case number is 1-1669000031884.
Kindly,
Ai
09-24-2021 01:41 PM - edited 09-24-2021 01:42 PM
Hello Sassy,
Thank you for your patience with us! We've created a case for your issue to send to our support team. Be on the lookout for an email from us in your inbox soon. For reference, your case number is 7-7641000031874.
Kindly,
Ai
09-27-2021 11:29 AM
Hey all,
It's been a few days since the last reply, and I am going to lock the thread at this time. If you have any questions from here, please feel free to create a new post.
