Compressor turns on when selecting fan mode
Teslacapt
When selecting fan only, the compressor is coming on every time.  (Yes the temperature is set higher than current inside temperature.  So AC should not be  coming on). What gives?  Older nest thermostat at our main house works normal but this POC is terrible. Non Wi-Fi we replaced worked normal and just fan would turn on. Is the quality this poor on nest thermostats?
nest thermostat hardware version 1.4
davehoney
thanks for your information
