Connecting wires? Am I doing it right?
TkinNC
What do I do with the black wire and the letter C that has no wire? I just matched colors.
7 REPLIES 7
Houptee
No you are connecting the wires wrong.
Watch this video
https://youtu.be/Gcko5IrB1AY
@TkinNC, thanks for reaching out and I wanted to chime in.
I just want to confirm if you have already visited the link provided by Houptee. It will help you to install your Nest Thermostat. Also, you can visit this article for additional information.
Please let me know if you have any questions or concerns as I'll be willing to assist you from here.
I appreciate your help @Houptee
TkinNC
I thought I could post two but I guess
not
You are inserting the wires wrong they go in the side holes not those holes. First push the tab down and insert then let go.
Was the blue wire connected to the old tstat? That is usually the C wire but it also has to be connected to the C screw inside the air handler for it to be used as a C wire so you have to go to your system remove the cover and look if blue is on the C terminal screw. If not connect it and then put in C on the Nest.
@TkinNC, we’ve duplicated your thread with the main one here. You’ll receive all updates on this issue on the main thread, and we recommend updating and checking this thread when needed.
Thanks for assisting, @Houptee.
EmersonB
@TkinNC I'm dropping by to ensure that everything is covered here. How's it going with your Nest Thermostat? Were you able to wire it properly? In case you have an update or questions, you know where to find us.
I appreciate the help, Houptee and Jenelyn.
EmersonB
Hello TkinNC,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, I would be happy to keep it open. If there's more we can do, just let us know.
