09-05-2021 11:26 AM
I’m having a problem with my nest saying that it’s not getting any power from Y1. I replaced the fuse this morning after getting e24 error and now this. Any suggestions?
09-09-2021 02:35 PM
Hey there Remarkable1,
I can definitely understand the confusion when it comes to thermostat issues as it can be very odd to figure out sometimes, but I'm happy to look into this for you.
First off, I would suggest using the Compatibility Checker to see if your system is compatible. Then, if it is, I would suggest contacting a pro to come out to help you with this since I know that the Nest thermostat is not compatible with stranded wires, every wire has to be connected to the Nest Thermostat system.
Please let me know if you have any further questions or concerns as I'm happy to help.
Garrett DS
09-12-2021 07:04 PM
Have a great day.
Hilary
09-15-2021 09:55 AM
Have a great day,
Garrett DS
