Fan stays on after heating stops
asc222
When I set thermostat above current temp, the heat comes on for about 5 minutes then it seems the heat stops and cool air comes out of the vents. I think it's just the fan blowing room temp air around (not air conditioner) but it feels annoyingly cold. About 5 minutes later fan goes off.
Technician said that Nest Learning isn't compatible with heat pump and aux heating system, but I find that hard to believe.
Anyone else have/fix similar issue?
8 REPLIES 8
That tech doesn't know anything.
Is this a new install or one that was working and now isn't?
Any chance you have a picture of the original thermostat's wiring?
I do have pics of wiring to old thermostat and to Nest. How do I upload pics here?
You can just drag and drop them into the edit window that you type your message in
asc222
Old thermostat:
Nest thermostat:
Nest settings:
I'm thinking that I may need to change the Heat Source 1 setting to 'Heat Pump', but not sure if that fixes the problem
Thanks
Ryan_G
Hey asc222,
It is important that we select the right heat type and heat source for your Google Nest thermostat. This will provide your Google Nest thermostat the right information on how to manage your unit.
Let us know how it goes after changing the heat type and source. You could go to settings > equipment.
Thanks for the help, @Patrick_Caezza.
Ryan
Sorry for not replying sooner, this forum's software is terrible at notifying when a reply has been made.
I'm a little confused about how you wired the Nest base. Your original thermostat has four wires connected to it, but you have five wires connected to the Nest base. Where did the yellow wire that you have connected to the OB terminal come from?
Going by your original thermostat's wiring your have a conventional system  and not a heat pump.
Thank you Patrick and Ryan for your help..
The system is in a condo building that has a cooling tower for air-conditioning. My understanding is that the cooling tower is only for air-conditioning but the HVAC tech who installed my replacement air handler says the cooing tower acts as a heat pump to provide heating too. I think he is wrong and will have to confirm with the building manager.
In any case, I removed the yellow wire and changed the Nest settings to "heat source: electric" and "heat type: forced air" and that seemed to fix it. The heat comes on when temp goes below thermostat setting and stays on until the setting temp is reached. HOWEVER, when the actual temp goes below the set temp again, system will not come on and I get an error message on the Nest and the app:
I'm not sure, but it seems like if I turn the circuit breaker for the HVAC off and on, it resets and it starts working again. (All the wiring in the Nest is firmly seated where it should be).
Could this be a bad Nest (HVAC tech thinks that is the issue) or HVAC issue or ????
Ryan_G
Hope this helps!
Kind regards,
Ryan
