08-14-2022 11:24 PM
I've seen a number of requests for shorter interval/timing for hot water on this forum. However I've not seen a proper product manager reply to such feature requests. This would be an immensely useful feature for your customers to save energy.
We used to have hot water on for an hour in the a.m and and hour in the p.m. this used to use 11 or 12kwh of gas per day. I could not quite figure this out as a 17kw boiler should heat a 200L water tank from 40 to 60 degrees in about 16 mins. So I cut the time down to 30min intervals and halved the usage to 6kwh per day and noticed no discernable difference in hot water availability. The cylinder stat is set to 60 degrees - I wonder how accurate these are - and of course there is a loop of pipework being heated too.
So we need to have control of hot water heating down to the 5 minute level, this will help people save energy. All you have to do is allow it in the app and web app. I noticed you can input a 5 minute time - but it will not save it.
Please enable this.
08-26-2022 02:47 AM
Thanks a lot for sharing your thoughts on this matter. I totally hear you and perfectly understand the situation. I can assure you that our customer's interests are our main target and that's why we take every piece of advice as a future reference to improve our products and services. Rest assured that this information will be passed to the most appropriate part of this department. Also, since we don't have any updates regarding the heating time for hot water, I'll kindly recommend you to keep an eye on the official Google pages for news. I appreciate your interest.
08-28-2022 02:59 AM
Hi, I wanted to check in. Is there anything else you need assistance with perhaps? If there is, make sure to let me know.
08-30-2022 03:01 AM
Since I haven't heard from you in a while, I'll have to close this thread. Should anything else come up, please open another thread and we'll take it from there. Have a good one and stay safe!
