First Set Up - Not Cooling
Cnelsen74
    Tried to set up thermostat the other day. Was about 95 degrees outside. Set it up, left for an hour with it set to 69 on cooling and came back, was 85 degrees inside lol.It said it detected all 6 wires. Had to throw the old thermostat back on. Local HVAC company told me $363 to have it wired up.
    Making sure I wired this correctly, how does this look? (Don’t know if it’s important but I have a heat pump). Also, black wire was never connected to anything.  I’ll try to post the photo here in a second.
2 REPLIES 2
luciaaa
Hi, @Cnelsen74 ,
Thank you so much for posting in the community and sharing pictures of your thermostats. I’m happy to assist you.
After checking the wiring configuration, here's how to connect the wires to your Nest Learning Thermostat (3rd generation):
  • Red wire goes to RC.
  • Yellow wire goes to Y1.
  • Blue wire goes to C.
  • Orange wire goes to O/B.
  • Green wire goes to G.
  • White wire goes to W1.
Let me know how it goes.
Ana.
Works perfectly now, thank you so much!
