Flashing red led on 3rd gen nest. App says battery level 3.83, no display on screen?
REDled
Nest just stopped turning air conditioning on, and only shows a red flashing led on the display. Checked Technical info on app which shows battery level 3.84 volts. Any ideas what to do will be rewarded with many thank you's...
2 REPLIES 2
REDled
Update to add, removed nest and charged thru usb connection, reinstalled.  Now app shows 3.67v but the display is back on and working the AC. Another piece of misinformation from an android app. Cannot trust the app when it comes to the voltage reading of the battery.  Display said something about turning off the system so the battery can charge.
moralesvicente
Hello REDled,
Thank you so much for posting in this community. It seems your Nest app is showing a different battery voltage for your thermostat. Don’t worry; I’m here to assist you.
Based on the previous troubleshooting steps that you have performed, you need to:
  1. Reset your thermostat: This step might resolve the discrepancy and make the thermostat and the app show the same battery level.
  2. If resetting doesn't work, remove (uninstall and reinstall) the Nest app from your device and pair it again.
I hope this information helps.
Daniel
