09-15-2023 02:21 AM
My hot water has suddenly stopped working after about three years without a problem.
If I turn on the boost I hear a click and the moterised valve opens but the boiler and pump do not turn on.
The central heating still works fine.
Help
09-15-2023 05:02 AM
Call a plumber - most issues have nothing to with Nest. It's more likely your boiler has a problem.
09-16-2023 05:05 AM
Your right, on checking it's the motorised valve not calling for heat, now as sorted
09-18-2023 08:30 AM
Hi there @PETERUKW! The symptoms that you described, indicated that the Nest system worked fine. I'm glad to hear that you managed to sort out the issue. @Spinstorm Hello to you too, and thanks for the input.
I apologize for the late response, but if there is anything else I can do for either of you, please leave a reply on the thread and I'll be glad to help.
09-22-2023 07:17 AM
Hello there! Just checking in with you. Did you see my colleague's previous message?
09-22-2023 07:37 AM
The fault was with the motorised valve not sending signal to pump and boiler, now sorted
09-22-2023 08:05 AM
I'm so glad to hear that the issue was sorted out. Is there anything else me or my colleagues can help you with?
09-25-2023 08:07 AM
Hi, just wanted to check in. Anything else I can perhaps try and assist with?
