11-15-2023 06:27 AM
I have nest learning thermostat (downstairs with furnace) & nest thermostat (upstairs with heat pump) installed few weeks ago. This week, i noticed both the floors keeps heating up beyond set temperatures on thermostats. Not sure, why. Can you help?
Thanks.
CP.
11-19-2023 09:49 AM
Hi chiragcpatel,
Thanks for reaching out. I'd like to know more about it. A few questions: what type of Nest Thermostat do you have? In what country are you located? Have you noticed any messages or codes on your thermostat or in the app? Please provide your thermostat's power readings. Also, checking your thermostat's Energy History will help you identify what your thermostat is doing previously.
You can follow the guide below to check the power readout:
Nest Learning Thermostat and Nest Thermostat E:
Nest Thermostat 2020:
