Having Issues with nest thermostat on heat and cool
BenjiFrank
Not sure if the problem itself is related but recently during the winter had problems where the automatic fan was blowing cold air instead of heating the home, but a reset to the thermostat got the heat blasting again. With recent season changes now that I am in cool mode the condenser, evaporator, suction line, and metering device are all freezing and I have had to shut down the unit to let it thaw. Any thoughts on what could be causing these issues?
AxelD
Hi BenjiFrank,
Sorry to hear about this situation with your HVAC system. Based on the post's information, I can see that the thermostat is cooling. So, that means it's sending the signal to your HVAC system, but the system isn't regulating how freeze is sent. it seems to be an issue with your actual HVAC system. My recommendation would be to contact a local professional or a Nest Pro to check it.
Axel.
