10-28-2023 08:12 PM
Nest is online, breakers have been reset, has only powered on once and for 2 seconds. Have restarted the nest within the thermostat, no results.
10-31-2023 10:34 AM
Hi KMcGehee,
Thanks for reaching out and for being a step ahead of us. A few questions: what type of Nest Thermostat do you have? In what country are you located? Do you have a C wire? Is your thermostat newly installed? Please check your thermostat's Equipment and check if you'll find any messages or codes there. Also, provide your thermostat's power readings.
You can follow these guides:
Thermostat's Equipment
Thermostat's Power Readings
