11-11-2022 08:05 PM
had a new package unit installed in May 2022. Nest learning thermostat recently has not been heating the house. Is set to heat. Lights up orange. No hot air blowing.
11-15-2022 04:27 PM
Hi MediumJay,
Thanks for reaching out. I'm sorry to hear that you're having an issue with your Nest Thermostat. I'd love to know more about this and I have a few questions:
Edward
11-15-2022 04:28 PM - edited 11-15-2022 04:30 PM
I have same issue nothing in heat mode AC works so I moved the hot and cold wires it came on in heat mode but blowing cold air
11-15-2022 06:46 PM
Hi BradJones,
Thanks for sharing. I'd like to clarify what happened in your situation. Did you swap the Y and W wire? If the wires are still swapped, could you try to call for cooling and check if it's going to blow hot air?
Edward
11-15-2022 07:30 PM
I thought about trying that but didn’t want to mess it up
11-20-2022 05:46 AM
So turns out our 7 month old heater, which is part of a package unit, had a motor for the heater go bad. Not a nest issue at all. Thanks for the support EdwardT, and everyone here.
11-21-2022 02:38 PM
Hi MediumJay,
Thanks for the update. I'm glad to hear that you were able to find what's causing the issue. Let us know if you have other questions and we'd be glad to assist you.
Edward
11-24-2022 02:41 PM
Hi MediumJay,
Edward
11-30-2022 03:50 PM
Hi MediumJay,
Edward
11-30-2022 08:12 PM - edited 11-30-2022 08:12 PM
Thanks for checking in. I already updated the post. It was the package unit. Nothing to do with the thermostat. Thanks for your diligence. 😀
11-30-2022 08:52 PM
Hi MediumJay,
Thanks for the update. I will be locking this thread in 24 hours. Please feel free to create a new thread should you have some more questions or concerns in the near future and we'll be more than glad to help.
Edward
11-15-2022 07:36 PM
I flipped and called for cold air and doesn’t come on at all.
11-16-2022 04:25 PM
Hi BradJones,
Thanks for the update. We'd like to know more about this. Please fill out this form so we could investigate further.
Edward
11-19-2022 04:33 PM
Checking back in — have you had the chance to fill out the form?
Mel
