Heating comes on when water is scheduled
Mark770
After a year of working fine, my heating has suddenly started kicking in when the hot water does too. This is despite the temperature not dropping enough to need heat.
2 REPLIES 2
JosieP
Same is happening to me - did you find a solution to this?
q_
I have the same issue with my 3rd gen thermostat. Everything has been working perfectly for 3 or 4 years, it’s started happened in the last 6 months or so iirc.
Is anyone else experiencing this, or know what the issue is?
