01-28-2023 10:45 AM
Will this work with a nest thermostat ?
01-28-2023 05:15 PM
Yes, this will work with Nest Learning Thermostat, Nest Thermostat E without the c wire, and for Google Nest Thermostat, c wire is mandatory.
02-02-2023 09:55 AM
Hello there,
I appreciate your knowledge here, @eveluna.
@Alexjr2112, Thanks for posting your thermostat's wiring setup. I can confirm that your system is Nest-compatible. But please make sure to follow the wiring setup to ensure the right configuration. You can also check your system’s compatibility before purchasing a Nest Thermostat with our online Compatibility Checker.
If there’s anything else we can help you with, please let us know.
02-07-2023 07:37 AM
Hello Alexjr2112,
I wanted to see if you still needed help checking your system compatibility. Please let us know if you have any other questions or concerns.
02-08-2023 09:10 AM
Hi Alexjr2112,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before I lock this thread in 24 hours.
