05-21-2023 01:27 PM
Good day
I have had a few Nest Learning stats and each have the same issue. There is no way of 'Advancing' the hot water...
Scenario: we've all had showers, baths, washed etc. and then we're off out and coming back with no requirement for any substantial amount of hot water before bedtime. I know that there is an hour or so of hot water scheduled still. I can't find any way to 'skip to the next scheduled event' at all!!!
All I'd like to do is cancel the current call/demand for hot water as I know we don't need it.
I've 250l of hot water storage and it is unnecessary to heat it when there's no requirement for it!
Hope I've not missed something, but I cant find out how to do this.
If not this needs to be added as a feature request ASAP
05-28-2023 08:50 AM
Hello there! Thanks for posting and I'm really sorry for the late reply. From what I understand, you can erase the Hot Water schedule by going into the Nest App, press on the thermostat that controls the Hot Water and try to remove it from there. For the times when you need to use hot water, you can boost it for 30 minutes.
Many thanks, Oana.
05-31-2023 10:08 AM
Hello there! Just checking in with you. Did you see my previous message?
06-02-2023 02:37 AM
Hey there, we haven't heard from you here in a while so I'll be locking this thread. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community. Thanks, AlexD.
